Me too, but the 4mm doesn’t fit. Having said that, I’m now being pushed to buy something I might not need, and I do want to get this machine up and running in the next couple of days!
The precise quote is: “They use a 3/32” hex wrench. I have one now but in a pinch I used needle nose pliers the first time I needed to change out a board".
-I have a 2016 XXL that I replaced the controller on and the original one with the big heat sink had a few SAE/Imperial screws. It was over a year ago that I did t he replacement and I have 2 sets of Wera Allen sets so I dont remember which screws were what but some were not metric.
So your screws have to be metric or imperial because those are the only two measurement systems used on modern screws/bolts.
I agree, mainly because I can’t think of any alternatives to imperial or metric! It does appear though that the Carbide3D-provided 2.5mm Allen key is, in fact 3/32" (according to my vernier calliper), but the round part on the end could be why it doesn’t fit! I’ll see if a proper 3/32" key fits when it arrives.
I am glad the modern world has gotten simpler in that regard.
My 1974 Series 3 Land Rover is a nightmare to work on, it has UNC, UNF, BSW, BSF, metric and Withworth fasteners.
It’s like they used what was left in the parts bin when they assembled the vehicle.
I’ve got two old, standard Allen keys, the Carbide3D-supplied Allen key and I’ve just bought a set of Chinese-made Allen bits - all of which measure 3/32" on my digital Vernier gauge.
The old ones are too big to fit in the recess, the rounded end of the C3D one makes it slip out of the recess, but the bit fits perfectly, so I was able to use that to do the job - to put it back together, at least. I had to use a T10 torx head drive to unscrew them in the first place, as the order for the bits hadn’t arrived in time!
I bought one of these sorts of kits as an insurance policy for these situations:
There are some more famous ones available from the people who take things apart professionally.
For me, the 3/32 one in this set worked just fine on those screws when I replaced my controller board, but the bits here have hollow points which seem more appropriate for shallow slottings.
