I have run into the problem of not seeing the parameters of older build version files. Is this the case or am i not doing something right?
I have the same problem with earlier versions. Cant tell you whoch versions. I just deleted old tool paths and recreated them and it worked fine.
If you have an older file which doesn’t work when opened in a newer version please send it to support@carbide3d.com
The files do work but I just don’t get to see or change any of the dims should I need to. I did figure out that if I need to I have to run through and basically rebuild the tool paths which kind of adds to the overall workload.
Thanks guys!
