I’ve just about finished my design and suddenly the grid and design reduce itself to about 1/16".
I’ve just spent a long time trying to figure out how to bring it back to proper size. I can use the mouse wheel to enlarge it’s size but the design and grid are off to the right side of the screen. I’ve tried to “undo” to back out of the problem to no avail.
Any help would be appreciated.
TW
Ok Lester…here is the file, I hope it is usable. Notice my design is moved away from the grid because I was trying different options to get the grid moved into the work area where I could enlarge it. The red line is supposed to be a centerline, I also moved it off the grid as I tried different things.
thanks for helping.
TW
The centerline was the issue. You have a workpiece defined as 2.5 x 2.5 and the center line was 73.5 wide. I deleted the centerline grouped the rest of the drawing and centered it in the workpiece. Carbide Create-DPDT-Base_Bottom-v3 Centerline removed .c2d (88.3 KB)
Lester-
Perfect !! Thanks for rescuing me from my own demise :).
I’ve just started using CC and for the simple things I do, I really like it. I have a TAIG CNC mill with Mach 3, cutting mostly Alum. and Brass.
This design will produce parts for a telegraph key ( morse code) I’m working on.
