I just received my Nomad today and gave the first tutorial a run and… encountered my first ever CNC fail! It was looking really good to start, the first plunge was smooth and effortless, tracing the outline of the wrench was going smooth as butter until it almost completed the first pass of the outline and then stall, clunk, clunk, clunk… the spindle recovered and the job continued but the x axis was now offset by 6mm on the x axis so obviously the x axis had jumped a few teeth. In setting up the job, I thought I had my z axis zero dialed in pretty well, I’ve had a Makerbot Replicator for a few years and got plenty of practice with that and when the job started it moved from home to zero without touching the work piece but that being said, the result tells me that I may have had the z axis zeroed in too close to the piece causing the spindle to stall due to some unevenness in the material at the point of failure where the depth of cut became too deep.
Second attempt, I zeroed z axis 0.1mm higher than before and the job completed 100% without any issues… success!!! The wrench wasn’t cut all the way through and had just the tiniest sliver of material attached which had to be cut and filed away but I’d call it a success all the same. It was a little bit scary with all the clunking with the first attempt (and fail) but nothing exploded or caught on fire so no harm done and the second attempt was near enough to being a complete success so all good there. Now that I’ve had my first run experience, I have some questions and comments that I hope can help improve the first run experience for other CNC newbs…
I assume (perhaps incorrectly) that the wrench tutorial was designed to mill all the way through the material. Given that my spindle stalled on the first attempt and moving z axis zero to 0.1mm higher on the second attempt avoided the stall issue, I would guess that I had zeroed too close to the work piece but then moving z axis up 0.1mm didn’t mill all the way through suggesting that I had zeroed too high. I can only guess that the tolerance in the tutorial is fairly tight and maybe splitting the difference at 0.05mm might have made the difference between not milling through the piece and milling all the way through.
The tutorial says that when trying to zero the z axis, it would be easiest to use a piece of paper to slide between the work piece and the bit and to stop when you start to feel drag on the paper. This is exactly the same method I use to zero my Makerbot so it’s a familiar process, however, opening the door on the Nomad results in Carbide Motion wanting to home the device again and you have to start all over. Am I doing something wrong here? What is the correct method to zero using a piece of paper without losing your position when opening the door of the Nomad?
May I offer one suggestion? Can you add a feature in Carbide Motion to fast move (or maybe not so much fast move but automated move) to zero? I can see that there are options to fast move to preset positions and I do understand that moving to a previous zero could result in a collision with the work piece if the material is of different dimensions to the existing zero setting but so could any jog movement. Maybe just pop up a warning first then ask the user to confirm that they want to perform this action? If collisions are a major concern with z axis then maybe just move to within a safe distance, say 10mm or so, then at least it would not be so far to jog manually?
Potential bug report - opening the door on the Nomad (specifically when using the move function) seems to crash Carbide Motion. What I have noticed is that I get the door open notification then I close the door and am presented with the option to load project or move cutter, so I click move cutter (to continue my calibration) then it says click to begin homing, so I click and then it hangs.
All that aside, I’m really, really happy to finally have my Nomad, it’s been more than a year of waiting but I really think it was worth the wait. I think the Nomad looks even better close up than in the photos and it is so much quieter than I expected! It is currently sitting on my desk only about 50cm from me and the noise doesn’t bother me at all, I think it’s probably even quieter than my old dot matrix printer for those old enough to remember them! Looking forward to some more adventures in CNC on the weekend when I’ll have a little more time to try something else on the Nomad.
