Yesterday I rewired my Jtech laser board to my shapeoko the wrong way and my shapeoko when beserk for a bit till I shut it off. After fixing the cables to there correct fit and trying to home my shapeoko 3 it said my homing cycle was not enable and when I jog my z and y azix go the oposite direction I don’t know how to fix this ? Can someone help
$0=10
$1=25
$2=0
$3=0
$4=0
$5=0
$6=0
$10=255
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=0
$24=25.000
$25=500.000
$26=250
$27=1.000
$30=1000
$31=0
$32=0
$100=250.000
$101=250.000
$102=250.000
$110=500.000
$111=500.000
$112=500.000
$120=10.000
$121=10.000
$122=10.000
$130=200.000
$131=200.000
$132=200.000
ok
I’d start by resending your machines configuration through CM
How do I do that ed?
Here’s a link on how to configure/set up your Shapeoko / Nomad.
https://carbide3d.com/hub/docs/shapeoko-setup/
Hope this helps.
That really depends on what version of Carbide Motion your running. Early versions allowed you to resend your config file I believe under the Settings tab, if memory serves correctly. Newer versions of CM with the setup wizard, you’ll have to setup as a new machine. With your machine power off but USB connected just launch CM and follow the on screen instructions.
All I had to do was uninstall carbide motion and install again thanks everyone
