Name the MC Etcher Tools 90 or 120
When viewing an existing project that was created using and MC Etcher tool, it is impossible to see if the 90 or 120 degree tool is used.
Can the 90 or 120 be added to these canned tools from Carbide3d?
Yes, I know that CM will say load the 503 or 504, but what about viewing in CC?
See attachment.
Unless I’m missing something, I don’t believe so.
Yes, but you have to add them to a User Library you created.
Right click on the first MC Etcher from the Carbide 3D Any-Any library and select Copy.
Paste that in a User Library you created.
Select the new entry, right click to Edit.
Adjust the Name field as desired.
And click OK. Select the tool from your User Library.
Edit: This is done in CC 815 Beta
