I have just installed Carbide Create build 464.
As I live in Sweden I use comma for the decimal separator.
In job setup I changed the units to mm and tried to change x, y and z to values containing decimals.
The result (if i open job setup again) is that all values are displayed as NaN.
If I put a whole number, it results in a decimal value using a dot.
If I change only the decimals the change does not take effect.
The same is applies to the parameters of shapes etc.
Is there a way to solve this?
Changing my regional settings is not a valid remedy .
I’m afraid that our software is not properly internationalized and that you will need to change your regional settings to use a period as a decimal separator rather than a comma in order to use our software.
Sorry to hear, but at least I got a swift and straightforward reply.
Hopefully you will add this functionality soon, so that we, comma practitioners, can use the software easily as well.
ugly workaround : you could create a specific user profile (Windows?) with a different regional setting, and log there to use CC ? Not convenient at all, agreed.
I took the easy route and changed the decimal separator, and live with it.
