I need to create 5 separate slits into hardwood that would hold a penny standing up. The slit needs to be deep enough to hold the penny without going through the would.
What bit and toolpath do I use in carbide create to not have the slit be so wide that the coin tips?
Any suggestions would be appreciated.
It shows 1.52mm (0.05984252" or 0.00266 smaller than 1/16" end mill) in thickness, but you will likely want a slight offset so the penny will fit in.
As a test - cut a contour of a line with a 1/16" end mill the depth you want the penny to sit. Test fit the penny and see if it goes in easily and is snug enough for your purpose.
A penny is 3/4" in diameter. If you want it to sit 3/8" deep, then the slot should be at least 0.750" long.
i.e. the penny will be sitting halfway in the slot.
If you have a 1/16" cutter, make the slot about 0.070 wide and use a pocket toolpath. This will give the cutter enough relief that it’s not cutting a slot the same width as the tool, with a little space to evacuate chips & prevent burning.
