Need a 4mm spindle collett
I mistakingly bought some end mills that have 4mm diameter shafts. are there collets for the standard Shapeoko Pro 5 spindle available?
https://carbide3d.com/hub/docs/65mm-vfd-spindle/
For the 65mm spindle they use ER 11 collets, that can be bought on Amazon.
There are other places to get them, this is just an example.
Hope this helps.
:smiley:
EDIT: If you have the 80mm spindle that uses the ER 20 collets.
https://carbide3d.com/hub/docs/80mm-spindle-kit/
