Hey all,
I have CNCjs installed on pi3 but when I try to access it in the browser, the pi blocks the connection.
can anyone help?
Thank you!
Hey all,
can anyone help?
Thank you!
Not a clue. But I’ll bet @neilferreri will jump all over this!
I cut wood and aluminum, he massages code AND cuts wood and aluminum.
can you elaborate on blocks the connection?
screengrabs are helpful
As @PaulAlfaro metioned, a little more info will help.
Also, it may be a version or two behind, but it doesn’t get much easier than this:
Thank you so much, A few questions. How do i update cncjs with this distribution? What is the purpose of having octoprint installed?
octoprint is for 3d printers. CNCjs is also included.
Here are the short instructions:
- Flash the SD with the image
- Edit the v1pi-wpa-supplicant.txt (not with notepad.exe)
- Put it in a pi, and go to http://v1pi.local
Sorry, just saw this.
Can’t test right now, but try:
sudo npm install -g cncjs
To give users the option in what machine they are controlling. The image was originally created for use with MPCNCs which can have a variety of controllers and act as different types of CNC machines.
