Im having trouble with a pocket cut going to far.
In the picture the pocket cut starts on the red line but i need it to stop at the line my cursor is on but instead it goes all the way through. My depths are set correct.
Upload the file?
Looks like you have doubled-up geometry.
What do you mean? The files uploads fine if thats what you mean.
He means upload it to the forum so the community can help diagnose.
Turkey call.c2d (388 KB)
heres the file
That toolpath is associated with the geometry where the pocket begins:
If you change the associated vectors to instead by with:
Ok
It may help to review:
https://carbide3d.com/hub/courses/create/object-manipulation/
https://carbide3d.com/hub/courses/create/toolpaths/
and further note that some colours of Layers may be confusing in terms of identifying what is selected:
But how does the complete cut stop at the brass shelf from outer void.
This is what the finished product should look like
Something like:
Then, work in/down:
Note that that pocket starts at the bottom and cuts down from there.
Then add the inner circle to the selection:
and assign another pocket:
Then cut the central pocket:
Then cut the holes:
and also cut away the surrounding material for a preview:
Here is a version in v8:
Turkey call_v8.c2d (1020 KB)
Thank you very much. Still learning this whole designing thing. Sometimes you just need thibgs broken down.
Eat the elephant one bite at a time ![]()
