Don’t know what I am doing wrong, but I set up a circle in Vectric for a .25 endmill, 0.04 cut depth to a total of a .5 inch cut with 4 tabs. When I ran it, the circle got progressively deeper very quickly to where it bogged down not even halfway around the circle.
I know a little about G-Code but have no familiarity with Arcs yet. Does anyone see anything obvious in my attached G-Code?
Thanks Circle.zip (490 Bytes)
but you’re cutting a slot just as narrow as the endmill, so have high tooling engagement which can drag the machine down into a cut — add geometry and cut as a pocket down to tab depth or the penultimate pass?
What version of Vectric do you have? I’d be happy to take a look at the design file for you if you can post it albeit, I have an older version Aspire 9.514 and don’t think that I can open Vectric files created above 10.0. Perhaps there’s a way to save the file in a compatible format?
