I’m not sure why when i try to pocket the letters out, it is pocketing the whole thing. its not leaving the inside lettering alone. see pic! Pulling my hair out. i placed red marking at the problem areas
You need to have selected the internal features to create islands in the pocket. These features must be closed vectors. For the ones with further internal details you may only want to select the outline. If it still gives you issues post the file here.
Here is the carbide fileLazaro sign.c2d (371.7 KB)
@WillAdams you’re just too fast.
I was just doing the same.
Lazaro sign modified lettering.c2d (374.8 KB)Awesome. Thank you so much!
