Wanna make some money with your shapeoko? I’m looking for a US manufacture to the propellers that I make. I can’t keep up with demand. $100 per finished product door to door. I have all the gcode ready to go and only requires 2x6" for wood. Each complete prop consist of 6 independent blades and a bullet nose.
Let me know if you are interested and I can give you more details. Requires an XL or XXL.
Will require 1099 information for taxes as an independent contractor.
you got some better technical specs on the parts? I have a friend who is an injection molder, it’s an expensive startup process, but could literally produce these by the millions per week.
Fair enough, mind if I ask what these things are actually for? I can’t tell if it’s intended to push air, or be pushed by air (latter makes more sense). I can’t tell much about how the wood grain is on these, since it’s painted.
I checked your other posts, gorgeous work. Sure beats cutting props out with a draw knife.
One of my hobbies is building off-grid emergency backup power systems, One of the projects I worked on a number of years ago was a small windmill, it had a swept area of about 3’, I tried a few different systems to use as generators, and ended up using BLDCs and some control electronics to control voltage etc.
It was a fun project, I’d like to return to it some day. Seeing your blades got me thinking.
