Nervous about moving the machine
Out of curiosity, has anyone had to move their machine? I have the Shapeoko Pro XXL and I need to relocate in the shop (small space redesign). It’s only a few feet but the base I built for it originally and the new base are both fixed.
Any tips or warnings would be appreciated. I’m pretty apprehensive, especially about the reset-up.
Get help.
Consider removing the spindle to reduce the weight.
Zip tie the carriage and gantry in place, plan out each stage of the movement.
should I disassemble any further than just the spindle?
For a few feet? Only if you can’t source assistance and you believe pieces would be more manageable and don’t mind re-assembly and re-squaring (FWIW, I lost track of how many times I disassembled and re-assembled my SO1 when first getting it set up).
That said, to channel an old quote from the original Shapeko forums:
I picked up the machine like an irresponsible badass and carried it out to the garage.
(though admittedly that was much easier w/ a 1M x 1M SO2 than the current, much heftier machines)
and I have to admit that I just moved my own SO Pro XXL single-handedly from one side of my basement to the other…
@vsedinger
I would get someone to help you move, just make sure the new table top is leveled across the top. It should be fine, I moved my 5 Pro with no issues from on table to another.
I used clamps to keep the x and y axis in place when moving my 4 standard. It helped a lot. I solo moved that because it seemed manageable at the time. I was moving it from basement to the car.
Re-set up is pretty easy. It’d probably be worth running a fun test project on some scraps after moving the machine to make sure it’s behaving as expected before you move on to the project on the one of a kind board made of unobtanium.
To add to Josh’s suggestion, I used zip ties when I shipped mine about 100 miles as well as removing the “Z”.
I was also thinking of removing a few of the mdf waste boards to lighten it more.
I wired up the new platform yesterday so it’ll be ready to plug n play.
Thanks to all who responded. I just had a minor medical procedure so I’ll wait a few days anyway.
After a year of having our house on the market and finally getting tired of waiting I ordered and set up my 5.1 with leg kit. 2 weeks later we got an offer.
No idea where we are going to go yet but it will be local. I don’t have any desire to take the machine apart so I plan to get a POD and roll it right in and strap it to the wall.
Add some padding between the machine and the wall, zip-tie the moving parts into a bottom corner (or at the center? Maybe pull an impression from photos of how the Nomad 4 is secured for shipping?) and unplug the motors from the controller and you should be good to go.
Congratulations on the home sale!
Congrats on the home sale! Hope your new place has a workshop… if/when I decide to move my new one will definatetly have a shop so I can move out of the dual purpose garage :laughing:
That’s one of the reasons we are moving. I have plenty of land here but can’t put a shop in due to HOA and doing any large projects in the garage is tough.
Thanks. Yeah, I have a lot of the foam from the original 5Pro packing so I will wedge that in there.
My only worry is the small wheels I have it on are good for the garage and probably the POD but definitely not my driveway so they will need to get the POD close or I will have to load down some plywood.
