New 4xl successes and problem
I got 4 projects successfully completed on the new 4XL but the fifth refused to start at the designated lower left corner.
Create file is correct and machine is initialized, offsets cleared and zeros reset. What’s up?
Also why does the machine take a tool measurement at initialization and then at the actual start of the job?
Post the file and step–by-step notes on how you are securing your stock and setting zero relative to the stock and managing all tool changes? A photo showing your setup would help as well.
The machine measure the tool after each time control has been yielded to the user in case the tool was changed.
My mistake! I assumed the machine would start at 0,0,0. After a couple more jobs I relized it was the job starting point!
Thanks!
