New 65 mm vfd kit always 24K rpm
I have tried everything I have found on this forum and generally online and can not figure out how to get the vfd to rpm at the speed sent in MDI as well as with a test cut via a project with CCreate. What am I missing! Always at 24000.
Thanks
James
Did you send the configuration for a VFD or a BitRunner?
https://carbide3d.com/hub/docs/shapeoko-setup/
VFD, tried set up a few times.
Check in with support@carbide3d.com and we’ll work through this with you.
I did, sent it to here and there.
Thanks.
Any chance you are also using Lightburn on this machine? If so, I’ll find my notes and elaborate, as there is a setting that will cause this if not returned to its correct value when going from Lightburn back to CC.
no, thanks though. working with the support team to get all taken care of .
OK - Hope you get it sorted soon.
For those using Lightburn, you run a macro before you use the laser, then another macro before you go back to CNC/Carbide Create. The important setting for the VFD here is $30. If you have a router, conventional advice is to set $30=1 when going back to CNC. This will cause a VFD spindle always run at 24,000 RPM. If you have a VFD spindle, you need to use $30=24000.
Here’s an example set of commands for an SO3XL:
USE LASER:
$32=1
$30=1000
$10=0
G10 L2 P1 X-825 Y-425
USE CNC:
$32=0
$30=1 (NOTE: $30=24000 if using a VFD Spindle)
$10=255
G10 L2 P1 X0 Y0
I’ll just add this in here…as I recall (also being a Lightburn and CM user) - it isn’t Lightburn that sets $30… it was actually CM that was setting $30 to 24000, causing Lightburn to not work properly…so we ended up putting $30 = 1000 into our “Use Laser” macro in Lightburn, to compensate / correct what had been changed. Then, you have to set it back to either 1 or 24000 in your “Use CNC” macro (as Steve points out).
So you would have to had created the Use Laser macro and added the $30 correction for this to be the issue.
  • G
You guys have a lot more going on in your LightBurn Macros than I do. My CNC is a standard size SO3 with the 65mm C3D spindle. Along with that there is a J-Tech 7 Watt laser I use from time to time.
My Use Laser Macro:
G10 L2 P1 X-425 Y-425
$32=1
My Use CNC Macro:
G10 L2 P1 X0 Y0
$32=0
What does changing $10 do?
It’s been a long time since I set up this macro, but from my old notes, $10=0 makes position values display as positive numbers in Lightburn.
