Specs: New guy, SO4XXL, Vectric, Neil Ferreri Post Processor, Carbide Motion…
I work in inches (don’t try to talk me out of it…old dog, new tricks) and just started using VCarve and decided the easiest post-processing would be done using the Neil Ferreri PP (thank you Neil!). The only PP I found is listed as mm. I tried just changing the UNITS statement to “INCHES” in the code and tried to run my job which was created in inches and the cuts were tiny (1/25.4 tiny I suppose). Questions:
Should just changing the UNITS to INCHES in the PP code work?
If not, are there any other things to do which would work for post processing in inches?
Is there any hidden, secret crap within VCarve that might help here?
Sorry for late reply. All is good with the inches PP. Thanks to Gerry for pointing me in the right direction and thanks to Neil for his work in writing decent software to help make the CNC world a bit less clunky.
Ok, please be easy on my inability to do anything with computers. What exactly am I downloading/saving/copying? How do I get the PP to download and upload on my software?
Use the mm post processor. It does not effect your workflow in inches at all. The conversion to mm is done in the background.
The downside to using the inches post processor is that the controller speaks in mm, and sometimes on arcs it doesn’t understand inches, stops, and throws an error relating to arcs.
The precision in the post processors should allow just about any arcs to make it through. That said, I’ve never seen an issue with arcs using a metric post processor.
