Hi guys. Just assembled my new Shapeoko 5 Pro and ready to go except waiting on the spindle. Is there anything I can do in the meantime? Can I run the machine with CM to test movement? Can i run the Hello World program without the spindle?
Sure. Learning the way CM behaves is good.
You can run the Hello World, but you will have to find a way to mount the pen and base your center off of that.
Or, if you are really dying to cut wood and the spindle will take a while then get the Makita or C3D router and then have it on hand as a spare once you have the spindle installed. If you buy the Makita it will come with the other attachments you would need to use it as a hand held trim router so you can do non CNC things with it as well.
Awesome. Great to hear. The spindle is supposed to be here tomorrow but I might not be able to set that up until later in the week. Since its Sunday I would like to do something.
I remember that day, I was the same way. While I was waiting for parts and few hick-ups with hardware I used that time to learn the software and watch tutorial videos on C3D website.
If I understand this correctly, I think you can include the whitecaps (as additional selections) in your pocket operation and it will effectively do both of those steps at the same time. Assuming your bit is small enough to fit into the tight spaces. If you upload the file it would be easy to check.
The 6 whitecaps are not connected to the other vectors. I can cut around the whitecaps in one pass but when I go to process the remainder as one, it will cut paths right through the whitecaps. That’s what I want to avoid and don’t know how to.
