The Curve tool will allow you to describe/draw a spiral, but it will not allow placing geometry along the spiral.
Please sketch out what you are trying to achieve, label it w/ dimensions, then post a .c2d file showing how far you’ve gotten and we will do our best to walk through this w/ you.
Thanks, It will take me a few days to get it all dimensioned. I still have to find out if your program is compatible with the CNC machine at school. UCF, Orlando Fla
I’m also looking for software to design flutes on the lathe. Holes will be located by tube length plus a radial angle, 0 thru 360. Possible oval hole and maybe undercut?
Yes, many of the functions in CC are not associative or parametric. Once the object is created, it’s just there.
You can’t move the grid. It’s always positioned from the lower left corner of the workpiece. You can only change the spacing. You can however, move the geometry relative to the grid, work on it then move it back to where it was. You have to get creative sometimes, and it helps a lot if you stayed awake during math/geometry class in school.
thanks. the only way I see to zoom, it with the roller on my mouse. When I zoom in, the grid slides to the left, going out of sight. I’ll try to just move the work back into view.
centering the long rectangles on the inner polygon, I see no way to snap node to a center point, will have to align each one by eye. ??
The toolbar w/ the “Upload” arrow appears each time you do a reply — this may depend upon permissions — I’ve upgraded your account, so if that was it, you should see it now.
sorry to ask so many questions, but I cant find any database to search. You’re my only source.
In “polyline”, is there a way to input length and angle with keyboard? The mouse is not accurate or controllable for precision.
when each is selcted, i see the “midpoint” on the central hegaxon sides, and on the connecting end of the long rectangles. But the two “midpoints” dont snap together.
so to re-state the problem, we want 12 rectangles, of increasing size, which are radiating out from a central circle, so that their increasing distance creates a spiral.
Since we don’t have dimensions, we’ll start w/ some arbitrary ones in a drawing program which has a feature which will obviate that need.
I sent files from your Carbide that are dimensioned, but it seems you cannot select a rectangle and see it’s parameters, except sometimes (4 out of 12 show the parameters, 8 do not)
EDIT: As noted below, the .c2d file above contained a set of rectangles which were supposed to be the correct dimensions, so was used instead of the proxies which were to be be made, eliminating the need for the work-around in this post.
Import the pixel image as a background for reference:
