How do I make a teardrop with Carbide Create?
How do you define a teardrop? Do you have dimensions? Do you mean in 2D or 3D?
It could be as simple as creating 3 arcs & trimming them??
2 D That is perfect. Thank you so much!
An alternate way to do this is with Node Editing:
Draw a circle:
Go into Node Edit mode:
Select the top node and drag up:
alt-drag the off-curve nodes to re-shape as desired:
For more on this see:
