Hi,
Being my second project, the first requiring me to use the First 30 days on Us warranty
, I created a simply Create project with two small pockets and then a larger outer boarder Final cutout, saved the file and the GCode.
- Opened Motion and connect to Shapeoko 4.
- Initialize - this moves back, right, and up, followed by moving to front center for a tool change.
- Put in new bit #102 and Resume. Triggers a BitSetter move that works great.
- Use Setting to Quick Move Center so I can put material in to Shapeoko 4
- With material secured use Setting to Set All Zero
a) Clear All Offsets
b) move to center of material and use paper test to lower bit. Set All Zero. - Load Job
- Optional - Use quicktask to verify x,y and 1 inch off material z setting. Newbie check.
- Run Job
- Request to install #102 bit and Bit Setter action occur. CHECK. Resume
- Set Router Speed to 1. CHECK. Resume
- Moves to first hole and starts cutting!!!
Moves to second hole and cuts!!! Yea. - Router raise out of material.
NOTHING HAPPENS now.
Expected: - Turn Router Off dialog. (Resume)
- Bit Change Request dialog. (Resume)
- Set Router speed to 3 and turn on dialog. (Rusume)
- Perform Final Cutout toolpath.
- Shapeoko moves to Back Center and Z=Top, so I can remove project.
I was able to stop the program and load a Final Cut only project to complete it.
Is there something wrong with the Project and/or GCode that is causing me not to see the expected dialogs?
Thank you for the help and any advice on the specific steps I am taking.
The DougMan
Irregular Shape holddowns 2_5.c2d (15.3 KB)
Irregular Shape holddowns 2_5.nc (20.6 KB)
