Newbie question.
Trying to recreate the CC logo I have tried Boolean and node edit. Not able to delete the remainder of my square.
How can I do it???
Carbide Logo.c2d (14.6 KB)
Thanks in advance
Newbie question.
How can I do it???
Thanks in advance
Personally, there may be an easier way…
Carbide Logo Polyline.c2d (25.0 KB)
→ Select All
→ Copy and drop next to original piece
→ Group original art and leave there
→ Create polyline and trace features you want on copied version
→ Delete what you don’t want on copied version
→ Select copy version and group together
→ Aline with original version (if you need to keep it in the same spot)
→ Delete original version and ungroup copy for tool paths
Boolean operations need to overlap.
Select the inner geometry:
Node edit:
Delete (or move) one node which will allow the parts to overlap as desired:
Done
Select the outer shape:
shift-click on the inner shape to make it the key object (indicated by a dashed highlight):
Boolean subtract:
If using a version of Carbide Create which doesn’t tidy up, delete the inner geometry:
Thank You Thank you. Was trying to do more than one vector at a time
