Testing more materials this time nickel
#122 no offset for pocket
#112 contour
You might be able to drill the top hole out with a pcb drill. A couple mm pcb drill at high speed works great.
(Assuming that is some kind of pendant. Also the tool change to a drill probably isn’t worth it for one offs but if you were doing a few at a time it’s more compelling
Looks great ![]()
