Making coasters on 4XL -
All went well until the Advanced V Carve step when no material was removed. Cutting a groove and cutout worked perfectly. I checked the zeros and the material thickness and a redo had the same result.
Regardless, it’s a very shallow cut. (The thickness of 3 pieces of standard paper)
Move your tool right next to the lines you are trying to cut & touch off the tool to the surface.
What does the Z register read on CM? Try setting your Z zero at this location.
Thanks Will!
I thought it would cut to the depth I set, but now realize that is the MAX depth.
I think I will try and do a contour cut with a 1/16" mill since I don’t know how to widen the lines.
I have a couple other graphics with fine lines that suffered too. I’ll try a 60 deg V on them.
Another question - If I run a test job then switch to a different thickness material for the final cut, do I need to reset the machine or just change thickness setting in CC and reload the file?
Changing the thickness setting in Carbide Create would only work if the origin remained unchanged — if it was set to the bottom of the stock.
If you have it set to the top of the stock you will need to both update Carbide Create (assuming stock thickness matters) and re-set zero relative to the surface of the stock.
Yes, if you have a job setup in Carbide Create, run it in Carbide Motion, and then want a section cut deeper you can disable all but the toolpath(s) you want cut deeper, set them to start at their bottom and cut the additional depth(s) desired, and then re-send them.
