No tool change prompt - ** Updated **
Hello!
I’m using a 5 Pro, after a dozen or so runs CM stopped asking for prompts and thus will not go to the bitsetter, It does stop for the change however. Code is coming from Fusion 360. All tools are numbered dif. No changes that I recall from running the last job. Thanks for any help!
The “Manual tool change” button in Fusion 360 has to be UN-CHECKED in the post processor tab. Go figure.
That sounds counter intuitive. Not sure how old that post is because F360 has updated their post processor and have seen no complaints about it lately. In the past Neil has custom written a post processor for F360 but have not seen any recent posts about the newer post processors. Maybe create a simple project and check the box to see if you get a different outcome.
Yep, un-checked it and ran correctly. It could very easily have been something I did.
