Hi all, it seems the induction homing switch for the Bitsetter on my Nomad 3 has stopped working. The red activation light on the switch is on all the time and the Nomad fails to initialize because the bit just crashes into the Bitsetter until the machine power is cut. Thankfully, the controller board seems to be fine.
Question is, can anyone point me to a replacement induction switch that will work with the machine? And, if I find that, how the heck to I get to the tiny hex screws on the aluminum block under the machine where the switch is located to remove the old switch and swap out the parts? I’ve tried the hex screws on the right side of the body that seem to hold that block in place, but it doesn’t budge.
Any help would be appreciated, Carbide’s support seems a bit backed up at the moment.
