Just a heads up that if you have your Bit-Zero plugged into the Nomad and the magnet/conductor is touching the surface when the Nomad tries to probe the length of the tool in the collet you will get an error. This had me baffled for a little while today since the Bit-Zero was hanging out of sight from view.
I was thinking that something was terribly wrong until I noticed the Bit-Zero was lit from closing the circuit. When I separated them everything worked perfectly again.
Loving my Nomad 3 so far!
