Nomad 3 Spindle Board
So I’ve burnt through a few of these in the first year of owning the Nomad. I love the machine but I don’t think it’s acceptable to have the board fry any time the spindle comes under a little resistance, there should be a cut-off in such instances to save the board overloading. In saying that, I can’t fault Carbide3D’s support to date but I will be out of warranty soon.
I’m now determined to do something about this board. The way I see it, there are two options:
  1. Replace the original board with a custom designed one
  2. Replace the original board with an off the shelf one
My first thought was simply using one of these controllers:
https://www.omc-stepperonline.com/digital-brushless-dc-motor-driver-12v-48vdc-max-15-0a-400w-bld-510b
Issue is I couldn’t get it to work with the stock Nomad 3 motor. I’m not entirely sure what the stock Nomad motor is, looks like a Brushless DC without hall sensor feedback. This controller should still work with it apparently, but so far, no dice.
So the next step was to replace the original Nomad 3 motor with this brushless one.
https://www.omc-stepperonline.com/24v-3500rpm-0-47nm-172w-10-4a-57x69mm-brushless-dc-motor-57blr70-24-02
In testing outside the machine these two work well together and stalling the motor simply activates the controller power cut-off, rather than frying the control board.
It would be great if a new controller board was released to address this issue, I can only imagine how many of these boards they go through.
Anyone have more information that could help in this endeavour?
An update…
I managed to get the Controller (BLD-510B) working, however it appears to not spin the motor as fast as the original board to the naked eye. I’m not sure why but it just feels much quieter and not as fast.
I have another controller on the way. I’ll see if that performs the same way. At $20 a pop, it’s a donation to science :joy:
