Hello everyone. So when my MDF wasteboard ended its life I decided to go with sea of holes one.
Since I was not feeling like paying $100 for it I tried to make a quick model of my own which just mounts on the stock Alu plate.
Here is a plywood sea of holes 10 by 10 6mm holes. Surprisingly 18mm plywood worked and it is very rigid
It is bolt on replacement.
If anyone interested in the model or gcode for Nomad833 let me know.
All you need to create one is 3.175mm ball end mill and 200mmx200mm plywood.
I haven’t gone through the original waste board on mine yet, but I did pick up a sheet of MDF and just recreated the original design and made a few extra. If you don’t mind sharing the files for yours that would be most excellent though! The more holes the better!
attached is an STL for my last version. I have lying around 5mm aluminum plate. Probably try this out on Alu this weekend but not sure if 5mm height will be enough to hold the bolts. Will see.
plywood-sea-of-holes.stl (503.6 KB)
