I was commenting on why every other nation in the world has adopted the same system of measurement, except for your country.
Collaboration to prevent errors, communicate in the same way. The motivation for the collaboration can be commercial and self-interest, not altruistic.
The idea that people adopt such things for the reason you mentioned (âover thereâ is better) is not strong as an argument.
The U.S. hasnât switched for the same reason that when you reach for a standard size hex tool bit itâs 6.35mm (1/4") â sunk costs â that said, metric should be used when collaborating unless there is a reason not to.
Iâve lived through transitions from imperial to metric in two separate countries. It wasnât particularly hard, and people and industry coped well enough.
(edit: Iâm okay using both personally⌠not saying one is better than the other⌠but one is certainly an international standard, which was the original point being made)
Iâve been avoiding the imperial vs. metric discussion, since there is no winning (Imperial is the name system- inches, et al-, the particular one used in the US being `US customaryâ, which assigns the values to names).
I will only note that I am looking at three sets of Jo-blocks right now, all with different inches. Two are US, pre and post 1960 (about 2 millionths different-- 50nm per 25.4mm is a big issue in the field I started in), and one is significantly larger that I canât identify, but the set is consistent with itself (made in Sweden Jo blocks, pre-WW-II, no idea which already-obsolete inch they were made to). Add to that there are STILL two different legal inches in the US, and there are cases where it is critical to specify which one.
There are advantages to a well-defined, reproducible unit.
Can we all agree the use of âmilâ in metric is just wrong? When the abbreviation is âmmâ surely it would be pronounced more like âmimâ???
Here in Canada it is a mish mash of metric and imperial and it has been for decades. I CAD in metric and have imperial tooling. Yes it is as fun as it sounds.
On the plus side I actually have mechanical calipers that do both!
I have the same caliper, but rarely use it. I have a wide variety of vernier with both, though. I also have a several mechanical micrometers that do both- Mitu combimikes- with one on the thimble, the other on the mechanical counter. I actually have both genders up to 50mm/2inch, due to lucky boot sale finds and all of the auto plants in the state closing over a 5 year period after 9/11. Honestly, more of a novelty than useful.
(I am in the US, NY/Philly metro) Most of the people I work with here either say it out -millimeters- or say `mimiâ, like from Drew Carey show. These are people from three (four?) continents, most of whom travel a LOT. Think container ship industry (my non-teaching 50% of life). I suspect that a lot of the reason is lack of comfort in english.
EVERYTHING we do is metric, and watching some of my US-born coworkers try to deal with it is hilarious. When I am in the shop, I probably say an inch is about 25 millimetres a dozen times every day. Then again, one of the reasons I get paid is that I can deal with metric/SI without making it a thing
[for ref: I speak both systems fluently, and marine is the third industry class I have worked as an engineer where this has turned out to be a key thing that makes me valuable. None of which are the branch my 35 year old degrees are in. Mostly because I also speak machining and welding fairly fluently, and construction passably. To go all facebook woke, my preferred pronoun/system is he/him/SI/metric, but I answer to pretty much anything I can recognize]
I think saying âmilsâ is fine. mm is a written shorthand for the word millimetre, so shouldnât influence how we say the word given it already sounds like âmilsâ. If it did, we should follow suit and use the written form of pounds (lbs) and try to pronounce them âelbsâ. Or says âdouble-quotesâ instead of inchesâŚ
As a metrically-inclined person, ever since I started CNC I have found myself using an awkward system which goes something like this:
1/4" and 1/8" are the sizes of those round thingies I use in my spindle. 6.35mm and 3.175mm sound like nice, round numbers to me now.
I manipulate the 0.001" (chipload) value all the time but my brain refuses to picture that as a dimension I can relate to.
For Stock to leave I use fractions of a mm because I can picture how much that is.
Feedrate values only sound familiar in inches per minute for some reason.
For long dimensions and dimensioning anything in Fusion Iâll use millimeters
whenever someone mentions any other value, I give up and launch the Windows calculator. I have divided or multiplied by 25.4 there so many times that if this was a physical calculator, the â2â, â5,â." and â4â keys would be completely worn out.
just mention 3/8" or 7/16" and I end up in a mental deadlock.
The double-sided tape provided by Carbide 3D with the Nomad, that they suggest you use as part of the starter wrench project.
When the machine cut though the bottom of the stock, bits of the tapeâs adhesive got stuck to the endmill, which then caused chips to get stuck to the tape. Those chips then basically ground away the ZrN endmill coating exposing the carbide underneath.
That is odd. I canât say I have ever had that happen.
I have destroyed coated tools many ways. Thatâs why they are called consumables. The goal is to get the most life you can from them, but sometimes things happen. The worst is a brand new tool and an incorrect tool path or zero. That always leaves me hearing both the cartoon angel and devil on my shoulders calling me âdumba**â. Fortunately, it doesnât happen often with care.
Problem is - there is already a âmilâ defined - a mil is 1/1000 of an inch. So a conversation where âYou need to take off a couple milsâ can cause the Mars orbiter to crash. Having engineering teams in both the US and any metric country has its momentsâŚ
