EDIT: Issue resolved. Appears the issue is with the G17-19 codes. I have it working now.
So I am using Solidworks with HSM, and then loading the GRBL into Carbide Motion to execute. I am trying to do just a simple contour cut of a rectangle as my troubleshooting piece. When I load the the GRBL into CM and then run the project, the bit does its beginning movements and then begins its descent to the top of the stock as expected. However when it gets to its cutting depth and should begin its rectangular path, it does not move. The spindle continues to spin, but the bit does not move in any direction. This is the code (also note that in the bolded lines, originally it says F0, but I change it to F10, otherwise I get an invalid feed rate error):
(2D Contour1)
M9
T7 M6
S5000 M3
G54
M7
G0 X6.563 Y15.601
Z15.24
Z5.08
G1 Z1.2 F67.7
Z-0.098
G18 G3 X6.462 Z-0.2 I-0.102 K0
G1 X6.36 F203.2
G17 G3 X6.259 Y15.499 I0 J-0.102
G1 Y0 F10
G2 X5.751 Y-0.508 I-0.508 J0
G1 X-0.749
G2 X-1.257 Y0 I0 J0.508
G1 Y15.499
G2 X-0.749 Y16.007 I0.508 J0
G1 X5.751
G2 X6.259 Y15.499 I0 J-0.508
G3 X6.36 Y15.398 I0.102 J0 F203.2
G1 X6.462
G18 G2 X6.563 Z-0.098 I0 K0.102
G1 Y15.601
Z-0.298 F67.7
G3 X6.462 Z-0.4 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-0.298 I0 K0.102
G1 Y15.601
Z-0.498 F67.7
G3 X6.462 Z-0.6 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-0.498 I0 K0.102
G1 Y15.601
Z-0.698 F67.7
G3 X6.462 Z-0.8 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-0.698 I0 K0.102
G1 Y15.601
Z-0.898 F67.7
G3 X6.462 Z-1 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-0.898 I0 K0.102
G1 Y15.601
Z-1.098 F67.7
G3 X6.462 Z-1.2 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-1.098 I0 K0.102
G1 Y15.601
Z-1.298 F67.7
G3 X6.462 Z-1.4 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-1.298 I0 K0.102
G1 Y15.601
Z-1.498 F67.7
G3 X6.462 Z-1.6 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-1.498 I0 K0.102
G1 Y15.601
Z-1.698 F67.7
G3 X6.462 Z-1.8 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-1.698 I0 K0.102
G1 Y15.601
Z-1.898 F67.7
G3 X6.462 Z-2 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-1.898 I0 K0.102
G1 Y15.601
Z-2.007 F67.7
G3 X6.462 Z-2.108 I-0.102 K0
G1 X6.36 F203.2
G1 Y0 F10
G1 X-0.749
G1 Y15.499
G1 X5.751
G1 X6.462
G18 G2 X6.563 Z-2.007 I0 K0.102
G0 Z15.24
G17
