People have expressed interest in seeing a Nomad vs. Shapeoko3 apples to apples comparison test. I own a Nomad883 Pro and a Shapeoko3 XXL and am willing to do some testing but rather than me deciding what to test, why don’t you tell me what you would like to see. If there are a couple tests that have a consensus I’ll run them and post the results.
Just to set the stage, the following are some of the major differences between the two machines…
Nomad listed first, SO3 XXL with the Dewalt DWP611 router) listed second…
Spindle power: 0.07 hp, about 1 hp
Spindle control: Closed loop feedback but not very responsive to load, Very responsive and stable.
Cut volume: 8x8x3, 33x33x3+
Accuracy: This is hard to nail down but approximately +/-0.001-0.003", +/-0.005-0.010" (both need more testing to have a better idea)
Setup: Setup from the factory (helps with accuracy), kit. It takes time to get it square and is difficult.
Drive type (xyz): lead screw for all, belt for all
Spindle speed range: 2000-10000 rpm, 17000-27000 rpm
Enclosed: Yes, No
Automatic tool calibration: Yes, No
Homing limit switches: Yes, Yes (although Carbide Motion makes it very painfully slow to home the SO3XXL machine so I’m not currently using homing on mine)
Stiffness: Subjective… Nomad is much stiffer than the SO3, especially the Z carriage assembly. I don’t know how much difference this makes. It probably affects finishes and accuracy of harder materials, possibly more.
Post any tests you would like to see. I’ll run them if there’s a consensus on one or two.
