Not cutting first pass -Shapeoko 3
Hi-
I am having trouble with my machine never cutting on the first pass. I have used both a probe and paper method of zeroing the z axis but neither address the issue. I have start depth set to stock top and bottom to .121 for 1/8" BB which is a little thinner than 1/8.
Thoughts? I have problem since day 1 and I wonder if I am doing something wrong.
Best
Z
What software? Did you set your work zero in your design to the bottom of the workpiece?
Is the material entirely flat? I have that issue quite often.
