After probing for x y and z, it does not appear that my xxl is getting the z axis zero setting correct. Im trying to cut out .75" pine but the z axis only cuts to .625" depth. I’ve read through a previous thread with a very similar problem and not been able to fix the issue.
I am using a xxl with z plus, a bitsetter and bitzero connected.
How are you probing for Z?
If probing only for the single axis, is the BitZero fully on the surface as depicted at:
if probing for XYZ all at once, then registered at a corner as depicted at:
I’m probing for xyz, so I set it like your picture 3/3. The lip on the bitzero is positioned per the directions.
Does your endmill reach the wasteboard?
Is the first pass too shallow as well?
If you cut 1/8" deep, does it actually cut 1/8"?
If you jog an inch, did it move exactly one inch?
After recently upgraded to Carbide Motion 5.21 my Z axis setup is not working properly.
Trying to run a simple pocket and using the probe for my XYZ settings. Using the front right corner as my origin with the machine bed as the o,o,o point. As the job starts its running way above, also if I stop the job and try to jog the position the program freezes up. Any ideas?
@wbpino Can you share the gcode?
I use Vcarve Pro to generate the gcode.
T1
G17
G20
G90
G0Z1.9311
G0X0.0000Y0.0000
S12000M3
G0X0.4250Y0.4250Z0.9862
G1Z0.7500F30.0
G1X0.4761Z0.7468
G1X0.4495Y0.4495Z0.7445
G1X0.4250Y0.4761Z0.7423
G1Y0.4250Z0.7391
G1X0.4761Z0.7359
G1X0.4495Y0.4495Z0.7336
G1X0.4250Y0.4761Z0.7314
G1Y0.4250Z0.7282
G1X0.4761Z0.7250
G1X0.4495Y0.4495Z0.7227
G1X0.4250Y0.4761Z0.7204
G1Y0.4250Z0.7173
G1X0.4761Z0.7141
G1X0.4495Y0.4495Z0.7118
G1X0.4250Y0.4761Z0.7095
G1Y0.4250Z0.7063
G1X0.4761Z0.7031
G1X0.4495Y0.4495Z0.7009
G1X0.4250Y0.4761Z0.6986
G1Y0.4250Z0.6954
G1X0.4761Z0.6922
G1X0.4495Y0.4495Z0.6900
G1X0.4250Y0.4761Z0.6877
G1Y0.4730Z0.6875
G1Y0.4761Z0.6873
G1X0.4495Y0.4495Z0.6850
G1X0.4761Y0.4250Z0.6828
G1X0.4250Z0.6796
G1Y0.4761Z0.6764
G1X0.4495Y0.4495Z0.6741
G1X0.4761Y0.4250Z0.6719
G1X0.4250Z0.6687
G1Y0.4761Z0.6655
G1X0.4495Y0.4495Z0.6632
G1X0.4761Y0.4250Z0.6609
G1X0.4250Z0.6577
G1Y0.4761Z0.6546
G1X0.4495Y0.4495Z0.6523
G1X0.4761Y0.4250Z0.6500
G1X0.4250Z0.6468
G1Y0.4761Z0.6436
G1X0.4495Y0.4495Z0.6414
G1X0.4761Y0.4250Z0.6391
G1X0.4250Z0.6359
G1Y0.4761Z0.6327
G1X0.4495Y0.4495Z0.6305
G1X0.4761Y0.4250Z0.6282
G1X0.4250Z0.6250
G1X0.4761F80.0
G2X0.4250Y0.4761I0.2739J0.3250
G1Y0.4250
G1X0.3250Y0.3250
G1X4.7375
G1Y0.4250
G1X0.7500
G2X0.4250Y0.7500I0.0000J0.3250
G1Y14.7500
G2X0.7500Y15.0750I0.3250J0.0000
G1X4.7375
G1Y15.1750
G1X0.3250
G1Y0.3250
G1X0.2250Y0.2250
G1X4.8375
G1Y0.5250
G1X0.7500
G2X0.5250Y0.7500I0.0000J0.2250
G1Y14.7500
G2X0.7500Y14.9750I0.2250J0.0000
G1X4.8375
G1Y15.2750
G1X0.2250
G1Y0.2250
G1X0.1250Y0.1250
G1X4.9375
G1Y0.6250
G1X0.7500
G2X0.6250Y0.7500I0.0000J0.1250
G1Y14.7500
G2X0.7500Y14.8750I0.1250J0.0000
G1X4.9375
G1Y15.3750
G1X0.1250
G1Y0.1250
G0Z0.9862
G0X0.4250Y15.0750
G1Z0.7500F30.0
G1Y15.0239Z0.7468
G1X0.4495Y15.0505Z0.7445
G1X0.4761Y15.0750Z0.7423
G1X0.4250Z0.7391
G1Y15.0239Z0.7359
G1X0.4495Y15.0505Z0.7336
G1X0.4761Y15.0750Z0.7314
G1X0.4250Z0.7282
G1Y15.0239Z0.7250
G1X0.4495Y15.0505Z0.7227
G1X0.4761Y15.0750Z0.7204
G1X0.4250Z0.7173
G1Y15.0239Z0.7141
G1X0.4495Y15.0505Z0.7118
G1X0.4761Y15.0750Z0.7095
G1X0.4250Z0.7063
G1Y15.0239Z0.7031
G1X0.4495Y15.0505Z0.7009
G1X0.4761Y15.0750Z0.6986
G1X0.4250Z0.6954
G1Y15.0239Z0.6922
G1X0.4495Y15.0505Z0.6900
G1X0.4761Y15.0750Z0.6877
G1X0.4730Z0.6875
G1X0.4761Z0.6873
G1X0.4495Y15.0505Z0.6850
G1X0.4250Y15.0239Z0.6828
G1Y15.0750Z0.6796
G1X0.4761Z0.6764
G1X0.4495Y15.0505Z0.6741
G1X0.4250Y15.0239Z0.6719
G1Y15.0750Z0.6687
G1X0.4761Z0.6655
G1X0.4495Y15.0505Z0.6632
G1X0.4250Y15.0239Z0.6609
G1Y15.0750Z0.6577
G1X0.4761Z0.6546
G1X0.4495Y15.0505Z0.6523
G1X0.4250Y15.0239Z0.6500
G1Y15.0750Z0.6468
G1X0.4761Z0.6436
G1X0.4495Y15.0505Z0.6414
G1X0.4250Y15.0239Z0.6391
G1Y15.0750Z0.6359
G1X0.4761Z0.6327
G1X0.4495Y15.0505Z0.6305
G1X0.4250Y15.0239Z0.6282
G1Y15.0750Z0.6250
G1Y15.0239F80.0
G2X0.4761Y15.0750I0.3250J-0.2739
G1X0.4250
G0Z0.9862
G0Y0.4250
G1Z0.6250F30.0
G1X0.4761Z0.6218
G1X0.4495Y0.4495Z0.6195
G1X0.4250Y0.4761Z0.6173
G1Y0.4250Z0.6141
G1X0.4761Z0.6109
G1X0.4495Y0.4495Z0.6086
G1X0.4250Y0.4761Z0.6064
G1Y0.4250Z0.6032
G1X0.4761Z0.6000
G1X0.4495Y0.4495Z0.5977
G1X0.4250Y0.4761Z0.5954
G1Y0.4250Z0.5923
G1X0.4761Z0.5891
G1X0.4495Y0.4495Z0.5868
G1X0.4250Y0.4761Z0.5845
G1Y0.4250Z0.5813
G1X0.4761Z0.5781
G1X0.4495Y0.4495Z0.5759
G1X0.4250Y0.4761Z0.5736
G1Y0.4250Z0.5704
G1X0.4761Z0.5672
G1X0.4495Y0.4495Z0.5650
G1X0.4250Y0.4761Z0.5627
G1Y0.4730Z0.5625
G1Y0.4761Z0.5623
G1X0.4495Y0.4495Z0.5600
G1X0.4761Y0.4250Z0.5578
G1X0.4250Z0.5546
G1Y0.4761Z0.5514
G1X0.4495Y0.4495Z0.5491
G1X0.4761Y0.4250Z0.5469
G1X0.4250Z0.5437
G1Y0.4761Z0.5405
G1X0.4495Y0.4495Z0.5382
G1X0.4761Y0.4250Z0.5359
G1X0.4250Z0.5327
G1Y0.4761Z0.5296
G1X0.4495Y0.4495Z0.5273
G1X0.4761Y0.4250Z0.5250
G1X0.4250Z0.5218
G1Y0.4761Z0.5186
G1X0.4495Y0.4495Z0.5164
G1X0.4761Y0.4250Z0.5141
G1X0.4250Z0.5109
G1Y0.4761Z0.5077
G1X0.4495Y0.4495Z0.5055
G1X0.4761Y0.4250Z0.5032
G1X0.4250Z0.5000
G1X0.4761F80.0
G1Y0.4250
G1X0.3250Y0.3250
G1X4.7375
G1Y0.4250
G1X0.7500
G1Y14.7500
G1X4.7375
G1Y15.1750
G1X0.3250
G1Y0.3250
G1X0.2250Y0.2250
G1X4.8375
G1Y0.5250
G1X0.7500
G1Y14.7500
G1X4.8375
G1Y15.2750
G1X0.2250
G1Y0.2250
G1X0.1250Y0.1250
G1X4.9375
G1Y0.6250
G1X0.7500
G1Y14.7500
G1X4.9375
G1Y15.3750
G1X0.1250
G1Y0.1250
G0Z0.9862
G0X0.4250Y15.0750
G1Z0.6250F30.0
G1Y15.0239Z0.6218
G1X0.4495Y15.0505Z0.6195
G1X0.4761Y15.0750Z0.6173
G1X0.4250Z0.6141
G1Y15.0239Z0.6109
G1X0.4495Y15.0505Z0.6086
G1X0.4761Y15.0750Z0.6064
G1X0.4250Z0.6032
G1Y15.0239Z0.6000
G1X0.4495Y15.0505Z0.5977
G1X0.4761Y15.0750Z0.5954
G1X0.4250Z0.5923
G1Y15.0239Z0.5891
G1X0.4495Y15.0505Z0.5868
G1X0.4761Y15.0750Z0.5845
G1X0.4250Z0.5813
G1Y15.0239Z0.5781
G1X0.4495Y15.0505Z0.5759
G1X0.4761Y15.0750Z0.5736
G1X0.4250Z0.5704
G1Y15.0239Z0.5672
G1X0.4495Y15.0505Z0.5650
G1X0.4761Y15.0750Z0.5627
G1X0.4730Z0.5625
G1X0.4761Z0.5623
G1X0.4495Y15.0505Z0.5600
G1X0.4250Y15.0239Z0.5578
G1Y15.0750Z0.5546
G1X0.4761Z0.5514
G1X0.4495Y15.0505Z0.5491
G1X0.4250Y15.0239Z0.5469
G1Y15.0750Z0.5437
G1X0.4761Z0.5405
G1X0.4495Y15.0505Z0.5382
G1X0.4250Y15.0239Z0.5359
G1Y15.0750Z0.5327
G1X0.4761Z0.5296
G1X0.4495Y15.0505Z0.5273
G1X0.4250Y15.0239Z0.5250
G1Y15.0750Z0.5218
G1X0.4761Z0.5186
G1X0.4495Y15.0505Z0.5164
G1X0.4250Y15.0239Z0.5141
G1Y15.0750Z0.5109
G1X0.4761Z0.5077
G1X0.4495Y15.0505Z0.5055
G1X0.4250Y15.0239Z0.5032
G1Y15.0750Z0.5000
G1Y15.0239F80.0
G1X0.4250
G0Z0.9862
G0Y0.4250
G1Z0.5000F30.0
G1X0.4761Z0.4968
G1X0.4495Y0.4495Z0.4945
G1X0.4250Y0.4761Z0.4923
G1Y0.4250Z0.4891
G1X0.4761Z0.4859
G1X0.4495Y0.4495Z0.4836
G1X0.4250Y0.4761Z0.4814
G1Y0.4250Z0.4782
G1X0.4761Z0.4750
G1X0.4495Y0.4495Z0.4727
G1X0.4250Y0.4761Z0.4704
G1Y0.4250Z0.4673
G1X0.4761Z0.4641
G1X0.4495Y0.4495Z0.4618
G1X0.4250Y0.4761Z0.4595
G1Y0.4250Z0.4563
G1X0.4761Z0.4531
G1X0.4495Y0.4495Z0.4509
G1X0.4250Y0.4761Z0.4486
G1Y0.4250Z0.4454
G1X0.4761Z0.4422
G1X0.4495Y0.4495Z0.4400
G1X0.4250Y0.4761Z0.4377
G1Y0.4730Z0.4375
G1Y0.4761Z0.4373
G1X0.4495Y0.4495Z0.4350
G1X0.4761Y0.4250Z0.4328
G1X0.4250Z0.4296
G1Y0.4761Z0.4264
G1X0.4495Y0.4495Z0.4241
G1X0.4761Y0.4250Z0.4219
G1X0.4250Z0.4187
G1Y0.4761Z0.4155
G1X0.4495Y0.4495Z0.4132
G1X0.4761Y0.4250Z0.4109
G1X0.4250Z0.4077
G1Y0.4761Z0.4046
G1X0.4495Y0.4495Z0.4023
G1X0.4761Y0.4250Z0.4000
G1X0.4250Z0.3968
G1Y0.4761Z0.3936
G1X0.4495Y0.4495Z0.3914
G1X0.4761Y0.4250Z0.3891
G1X0.4250Z0.3859
G1Y0.4761Z0.3827
G1X0.4495Y0.4495Z0.3805
G1X0.4761Y0.4250Z0.3782
G1X0.4250Z0.3750
G1X0.4761F80.0
G1Y0.4250
G1X0.3250Y0.3250
G1X4.7375
G1Y0.4250
G1X0.7500
G1Y14.7500
G1X4.7375
G1Y15.1750
G1X0.3250
G1Y0.3250
G1X0.2250Y0.2250
G1X4.8375
G1Y0.5250
G1X0.7500
G1Y14.7500
G1X4.8375
G1Y15.2750
G1X0.2250
G1Y0.2250
G1X0.1250Y0.1250
G1X4.9375
G1Y0.6250
G1X0.7500
G1Y14.7500
G1X4.9375
G1Y15.3750
G1X0.1250
G1Y0.1250
G0Z0.9862
G0X0.4250Y15.0750
G1Z0.5000F30.0
G1Y15.0239Z0.4968
G1X0.4495Y15.0505Z0.4945
G1X0.4761Y15.0750Z0.4923
G1X0.4250Z0.4891
G1Y15.0239Z0.4859
G1X0.4495Y15.0505Z0.4836
G1X0.4761Y15.0750Z0.4814
G1X0.4250Z0.4782
G1Y15.0239Z0.4750
G1X0.4495Y15.0505Z0.4727
G1X0.4761Y15.0750Z0.4704
G1X0.4250Z0.4673
G1Y15.0239Z0.4641
G1X0.4495Y15.0505Z0.4618
G1X0.4761Y15.0750Z0.4595
G1X0.4250Z0.4563
G1Y15.0239Z0.4531
G1X0.4495Y15.0505Z0.4509
G1X0.4761Y15.0750Z0.4486
G1X0.4250Z0.4454
G1Y15.0239Z0.4422
G1X0.4495Y15.0505Z0.4400
G1X0.4761Y15.0750Z0.4377
G1X0.4730Z0.4375
G1X0.4761Z0.4373
G1X0.4495Y15.0505Z0.4350
G1X0.4250Y15.0239Z0.4328
G1Y15.0750Z0.4296
G1X0.4761Z0.4264
G1X0.4495Y15.0505Z0.4241
G1X0.4250Y15.0239Z0.4219
G1Y15.0750Z0.4187
G1X0.4761Z0.4155
G1X0.4495Y15.0505Z0.4132
G1X0.4250Y15.0239Z0.4109
G1Y15.0750Z0.4077
G1X0.4761Z0.4046
G1X0.4495Y15.0505Z0.4023
G1X0.4250Y15.0239Z0.4000
G1Y15.0750Z0.3968
G1X0.4761Z0.3936
G1X0.4495Y15.0505Z0.3914
G1X0.4250Y15.0239Z0.3891
G1Y15.0750Z0.3859
G1X0.4761Z0.3827
G1X0.4495Y15.0505Z0.3805
G1X0.4250Y15.0239Z0.3782
G1Y15.0750Z0.3750
G1Y15.0239F80.0
G1X0.4250
G0Z0.9862
M5
G0Z1.9311
G0X0.0000Y0.0000
M2
Did you set your actual Z0 at the wasteboard or at the surface of your stock?
How did you set Z0?
I set the Z0 at the corner of the stock using the probe in the correct position. Made sure that the ledge was in the correct position and not on top of the material. CM521 does jog the mill to the correct Z +6mm position just before starting the job but once I start the run it goes way off.
But your Z0 is set at the wasteboard in V-Carve.
Correct (no negative Z values). OP is a little confused.
… a DUH moment here… I was confused because I tried to manually verify the XYZ settings before starting the job and the rapid movement command to set the bit to the current XYZ +6mm seemed to place the mill in the correct position, but that was because my setup was wrong all along…
Now still wondering why the software crashes after stoping the job and trying to move the mill out of the way.
I stopped the run as soon as I saw that the mill was just doing a ghost run. After stopping the job I tried using the rapid positioning commands to get the mill out of the way but CM521 freezes up. Not sure if this is a bug or just a way to prevent the machine from loosing its reference. The only way out is to reset the program.
I’m not sure where to go with my original issue as I’m completely lost with whats going on here…
I probed my xyz with the bitzero on my xxl, I’m also using a bitsetter. When I set the cnc in motion, the first pass was about 1/8" above my material. This made the contour .625 instead of the requested .75.
What would cause that?
Probing xyz with the probe entirely on top of the stock.
But you said you have the lip overhanging the sides?
Yes, the lip was overhanging the sides. I reopened the project in create to ensure my stock thickness was correct and it was. I played with the retract setting (the distance the z axis retracts when moving between tool paths) and was able to gain about .0625 in depth, but not the full .75 I programmed.
I also switched to a different project and did not have the same issue. It was a 3d topo map and it came out pefectly.
You mention updating the software. Did you update and resend the settings for your combo?
That wouldn’t affect the first pass cutting air. Neither would the retract height.
If you take the probes out of the equation (uncheck BitSetter and just set Z-zero by eye) do you get the save results?
I think I did, but not 100% sure. I will double check that.
The issue seems to be cleared up. Must have been not setting up properly during initialization. Thanks to all that have offered input! Have a safe new year!
