Not jogging after rapid movement to xy
connect to cutter
initialize machine - machine moves to back right (normal) then front right
JOG
rapid postion - rapid to current XY - machine moves to current XY
done
none of the movement buttons work xy or z ???
anybody else having issues lately?
What is the movement increment?
What happens on Fast?
doesn’t move on any setting. 0.001 - fast
after a couple minutes, the y starts working then everything else. weird. I would love to say operator error but I not doing anything I haven’t done in the past.
Power down, unplug from the wall, leave it sit for 30 minutes or so.
While waiting, reboot your computer and check for updates and check everything on the machine in terms of wiring, connections and mechanics.
Plug things back in, power up, wait 20 minutes or so, then check each wiring connector — they should all be room temperature, any which are warm/hot would indicate a poor connection.
Try to initialize and then jog.
If the problem persists, check in at support.
