I am machining a knife handle on two sides on my Shapeoko 3 XXL.
I have to do a reversal of the handle.
I have modeled the part and the machining part under fusion 360.
I encounter a problem that I can’t solve.
When I turn the piece I have a shift that appears on one of the two parts.
I keep the same origin, I have an imprint in my support plate which makes that when I turn my part it is lodged in it.
Everything is modeled under fusion (support plate, imprint, raw, wood block…)
Do you have any clues ? I admit I’m a little bit lost…
Could it be a problem with the machine? or with the firmware? if we rule out the modeling (which I checked 15 times)? maybe the belts are not tight enough?
In your design and modeling do you account for doelubke side machining. I have tried double siding with carbide create (non pro) with little to no success. However when I utilize Aspire and select how I am flipping i have had great success. I too only zero once with this method, i dont know if this helps or not but do know that whether I tell the program i am double sided machining or not does matter.
I don’t think there is an option in fusion on double-sided machining. At least I have never seen it.
I’ll take a closer look and hope to find something.
