Offset with Probe?
So today I used the probe to set my zero using a 1/8in 102 endmill using CM 428. After probing, I wanted to offset my zero 1mm on the X axis because my stock was just shy of the measurements and I did not want to change the project file.
I used the rapid position to go to X &Y Zero. After it went to zero, I went to the Set zero screen and saw that there was already a -0.0125 offset on both X and Y. It appears to be at the center of the bit but I don’t understand why there is an offset. Is this normal? Shouldn’t this be set at X0,Y0? Maybe I’m missing something. Trying to change that offset now becomes very complicated.
OK, I think I may have figured it out, the offset difference is due to the use of the BitSetter. I had set my initial zero using a 201 bit and did not re-home the machine. For the second job, I set zero with the 102 however, the difference between the two diameter is .125 and half that would be 0.0625. When I returned to the 201 and re-set zero for another job, the offset was 0.
Has anyone else with a BitSetter experienced the same thing?
@WillAdams can you confirm?
Aren’t those in mm?
Zero is based on the center of the end mill.
You are right it is in mm so why the small offset?
Rounding?
Stepper precision?
Maybe but it is the first time I see this. It would be nice to get explanation from the source.
