It said the topic was closed so this was my only way to respond… I was not looking at those instructions until about 3 hours in at a stuck point because nothing was making sense. Since then I have learned that updated instructions were supposed to be sent. It wasn’t until way later that I found them from this thread and printed them out. But I am still stuck because we have a black cord and this was very hard to understand after going all the way through the process once with only being able to put two and two together with our brains. After we realized we did in fact have to have the ring mount that we knew was missing from the beginning. We knew something wasn’t right from the beginning and at that point, i attempted to look it up because of the simple fact that we have the (keyword)" upgraded" z-plus. But had no luck. After some time I reached out to the forum. Hopefully they can get the ring mount over. nighted
are you looking at https://docs.carbide3d.com/assembly/shapeoko/xxl/Shapeoko_XXL_Assembly_Guide_v5_03_27_2020_web.pdf ?
Is your Z axis belt, leadscrew (Z-Plus, pg.21) or ballscrew (HDZ) driven?
Please contact us at support@carbide3d.com and we’ll do our best to work this out with you.
