Older machine with CM build 613
=Shapeoko3 XXL with Dewalt router spindle, upgraded PCB less than a year ago= A couple of years ago I added a relay controlled by the PWM signal to turn my router on and off. It worked flawlessly until I upgraded CM to build 613 today and had to start with a fresh configuration. Now the PWM signal doesn’t produce the >3v that it takes to turn on my SSR. What happened? I tried to revert to CM build 582 and although I reconfigured and sent the config to the controller, it still doesn’t work. How can I get that working again?
Ah, after sleeping on it I realized what to do. After enabling BitRunner it works perfectly again.
