Looking around for a place to mount the on/off switch I remembered having been gifted with this little vise a few years ago. It is great for holding small parts but does not see much use in my wood shop.
It was just the device to hold the switch securely in position. If I do need to use the vise for its more conventional uses it is still available.
I intend to order a emergency off button but for now I put a power strip on the front of my Shapeoko stand. It has come in handy a few times. I have the router and Shapeoko on the strip. Also if I need a light I have a ready spot to plug it in. I also keep a flashlight close by because it is dark under the router when trying to line up zero in the center of material.
I made a dual switch (one for CNC , one for router) that’ easy to get to. Doubles as a panic switch! I just leave the power switch on for the XL and tuck it out of the way
Used the machine to make a decora-sized hole in the plastic enclosure. Worked perfectly.
