I would like to machine the lines inside of the square first, and then cut the entire part out.
My problem is that when I create a tool path on the lines inside of the square, no G-code is created. Any help would be great!
Double check they are selected before creating the tool path. Open vectors are pink which I sometimes confuse for being selected when they are not. I just tried and it worked fine. Reply back if still no luck.
