Ok, I have a question for the smart people out there.
I have mounted an Opt Laser (Shapeoko kit) on my Shapeoko XL:
I have done almost everything I need to do, however, I’ve run into a roadblock. I have these two wires:
The brown one goes to PWM and the white to ground. It appears they designed this to go with an Arduino which has a place for these wires to plug in. I have the CarbideMotion 2.4e which looks like this:
The only PWM and GND I can find are on the upper right side:
These are labeled but there are no connectors there for them. I also have the BitSetter and the BitRunner, so when I get everything plugged in, it gets a bit crowded.
Is there another PWM/GND I can use?
Is there a plastic socket/plug I can add to this board? (Note that the other plugs seem to crowd it a lot)
Should I simply solder wires onto the PCB? I would prefer something less permanent.
Any thoughts or suggestions are greatly appreciated.
-e
