Has anyone added the OPT Laser to their machine? I got everything basically installed, buy having a little difficulty connecting to the Shapeoko 5pro panel. OPT direction say to go into the panel and access the circuit board. I believe the pro is a sealed panel. I need to access the GWN and GND pines. Are this accessible from the outside? In the accessory or auxiliary jacks? If so which pins would they be. And finally the cable from OPT has a blue and Red wire. Which goes where?
Someone please have an answer
