I often run the same single bit job multiple times. It would be nice if there was an option to skip the Bitsetter routine when I start the job or a skip button at the point where the routine asks me to change bits.
The work-around is to just disable it in Settings — the position will be retained, so it can be reenabled with just a check of the checkbox.
You can also remove the M6 command from the start of the gcode and that should work. Just remember that you have to install the right tool using the BitSetter before you start the job.
Second-ed on the unchecking the option in settings. I do that when I surface.
