I have been having issues with my bit crashing into the bitsetter. I have the new 5 Pro...
I know there are 2 ways of saving the G-code for order of operation “so correct me if I am wrong”, but 1. you can save each individual toolpath by disabling the others then saving them individually or 2. save the whole toolpath as one item.
Now, if I run the 1st option “running each toolpath separately” will I have to press the “load new tool” every time I need to change bits? If I go with option 2 the program will initial a tool change automatically and will not require me to click the “load to tool” tab because it is one continuous program?
I believe the problem I am having is when I run a project with separate saved toolpaths (where one program is done it goes back to Home, then I load the new program, change the tool (but I do not click the “load tool button”) it is not resetting the tool length correctly, which if not set to the correct depth as the last bit" it will crash into the bitsetter.
Please let me know if I am right or wrong on this because it is getting frustrating. All my limit switches are working correctly and the bitsetter lights are doing what they are supposed to do. Please advise.
What do you mean by “Crashing into the bitsetter.” ?
This should have nothing to do with the paths being separate or in 1 file. If you are using the “Shapeoko” post, it should be putting a toolchange command in the G-Code. ( M6T___ )
When CM sees the toolchange command with the bitsetter enabled, it should move to the toolchange position (front center), ask you to change the tool, move to the bitsetter to measure the new tool.
This is the same as using “Load New Tool”. So if the program is doing the toolchanges, you don’t need to use the “Load New Tool” button between paths.
One case that could get you in trouble is if you are setting your Z zero with the new tool before it gets measured. Because the measuring will offset the Z zero based on the difference in length between the last tool & the new tool.
If the tool is coming down on the bitsetter, and not stopping when it activates the switch in the bitsetter, it is likely that the signal from the bitsetter is on making it back to CM to tell it to stop.
Open the Settings menu & look for the page with the “Input Pin State” readouts. Push down the plunger on the bitsetter. The Bitsetter pin state should toggle on. If it doesn’t make sure all the connections from the bitsetter to the control board are good.
Phone calls are returned in the order they are received — for Mondays this can mean a bit of a wait as we work through the backlog from the weekend, but we will do our best to ring you as soon as we can.
