Howdy, having some new issues recently with the top right and bottom left corners of pockets. I’ve cut around 10 pockets to 1/2" and all of them have the same weird error. I checked the v rollers on all of the axes and as far as I can tell there is no slop. I just retightened the belts so I’ll double check in a second, I just wanted some other opinions before I try again. Using a 3/4 inch bowl bit with 1/4" radius from whiteside. DOC is .08 WOC is .15 with a feed of 45 because I thought maybe I was running it too hard. Doesn’t seem to make any real difference finish wise. Anyone encounter this problem before?20201230_150145|375x500 20201230_150204|375x500
Have you tried leaving a roughing clearance and taking a finishing pass?
