Hey guys, how do you fix this issue when you have the cursive type fonts and their paths intersect or overlap the next font?
You need to perform a Boolean operation, or a path offset (ideally twice, once outside by a tiny distance, then inside by the same distance.
See: https://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#boolean-operations
It may be that you’ll then need to clean up/delete some extraneous paths.
Thanks Will.
All I did was a small outside offset, then did the boolean and it worked. Had to delete the pieces that were still left like you said.
