Is this a bug?
I have carved two pockets which are the same depth. Where they overlap, it is deciding to omit to carve the overlap. Why is that?
maybe bug.c2d (24.5 KB)
Is this a bug?
Because overlapping and intersecting geometry pose logical problems for the program.
You have two options:
I am currently using your 2nd option but it means a bit of tidying up after cutting with the chisel/sander. I want to make multiple box sizes (these pockets are rabbets) so I cannot really unionise them.
PS. As you might have guessed this is why I tried to use Vectric but gave up!
Post a file to support@carbide3d.com ?
It might be something that the developers would want to look into.
FWIW, I had the same issue when doing miter boxes:
https://willadams.gitbook.io/design-into-3d/blind-miter-and-hidden-spline
