I have a job to run and of course, the laptop that has my install of carbide motion (literally it’s only job) has a system error and won’t boot into windows. IT went home for the day so, i’ll just install the Carbide Motion 6.18 on my desktop and connect it to the Nomad. I think the old laptop was running a 4.XX version.
Setup was no problem, connected, initialized, setup the stock and went to run a .NC file i’ve used before, only using the now dead laptop.
Now on this PC/CNC setup I get the following error (screenshot of Carbide motion with the applicable .NC file in NC viewer)
I will dig out a copy of the G-code standard and check and see if it specifies that it’s okay to nest parentheses thus, and if it does, will put in a bug report.
What CAM tool made that? Using what post-processor? Is there an option to not have it output nested parentheses? Perhaps you could edit the tool definition so that there aren’t any parentheses there?
I edited the parenthesis out of my tool crib and that worked.
I also verified that I can begin to run the .NC files with the nested parenthesis in Carbide Motion Build 4.0.412. It gets past the lines with the parenthesis but won’t actually run on the newer controller board from sept of last year. (parameters incorrect error)
